Can Slic3r be used to generate GCODE for a Prusa to function as a CNC?
November 15, 2015 01:05PM
Hi there guys I saw the other thread somewhat related to my question in this forum and decided to make my own. Please bear with me if I made some mistakes...
I have been trying to get my Prusa I3 to work as a CNC for soft materials for some time now. I have been trying to make it work with FreeMill, MeshCam and EstlCam, but I cannot seem to generate GCODE compatible with Repetier, and I'm not sure which combination of CAM software and GCODE interpreter to use.
I have been thinking about using Slic3r because I know it will work, I just need to invert the Z axis coordinates and lift the extruder head (read: mill) every time it moves outside of the print, or just keep inside the print so it doesn't cut through unintended material.
I would be grateful if I could get some help, and again please forgive me if the thread is irrelevant to the forum topic.
Re: Can Slic3r be used to generate GCODE for a Prusa to function as a CNC?
November 16, 2015 06:24AM
What seems to be the limiting factor to getting the gcode from other programs to work?
Any specific codes that Repetier doesn't recognise?
Maybe you could link a sample gcode file that fails to work with Repetier?
Edited 1 time(s). Last edit at 11/16/2015 06:25AM by Mikk36.
