Detect Thin walls not working
January 10, 2016 06:07AM
EDIT:
i just tried some more options and disabled "detect thin walls". now the gcode looks fine! smiling smiley
seems to be a bug in that option
iam trying to print a part with two small walls and i cant get it to work with slic3r.
tried turning on "detect thin walls" and reduce vertical shells but nothing helped.
with cura i can just reduce the shell thickness but i get much better print results with slic3r
i attached 2 screenshots of the part
any ideas? smiling smiley
thanks in advance
Edited 1 time(s). Last edit at 01/10/2016 06:52AM by dan_rep.
open | download - slic3r2.png (92.1 KB)
open | download - slic3r.png (406.7 KB)
Re: Detect Thin walls not working
January 13, 2016 07:36AM
I often try it with and without thinwalls. And with and without gapfill.
Sometimes a better fix is to design the part with exact wall thickness to match an even multiple of extrusion width. I'm now using 0.4 nozzle with 0.5 width, so a good wall would be 1 or 1.5 or 2 or 2.5 mm.
