Infill leaves gaps around perimeter
Posted by frankvdh
January 23, 2016 04:57PM
I'm using Slic3r 1.2.9, and found that when I fill a solid object, it doesn't join the infill to the perimeter. This means that the piece is much weaker than I want.
Below is a photo showing a couple of pieces which I've broken open. Top is a sphere which I expected to be filled completely with an infill, but as you can see there's a narrow pillar of 3D honeycomb (I think) up the middle, and a large space around it. The outer diameter of the ball (which is printed inside a socket, in case that's relevant) is 50mm. Below is a triangular piece printed at the same time, 10mm thick... again, there's a 1-2mm gap between the outer wall and the infill
Infill settings :
Is this a consequence of "Only infill where needed" being selected?
Re: Infill leaves gaps around perimeter
January 23, 2016 06:01PM
Yes I think so.
You can re-slice with that off and check the layers in the preview.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
