Printer hangs before printing January 31, 2016 02:44PM |
Re: Printer hangs before printing February 01, 2016 09:19AM |
Re: Printer hangs before printing February 01, 2016 10:33AM |
Re: Printer hangs before printing February 01, 2016 11:46AM |
Re: Printer hangs before printing February 04, 2016 01:02PM |
dmould
Then compare the first 20 or so command lines (not comment lines) in the print file from Cura to those from Slic3r. You should spot either a different command parameter or a missing command in the Slic3r file, which you should be able to fix in the start code.
If not, post the first 20 or so command lines from each file here.
Dave
Re: Printer hangs before printing February 04, 2016 01:03PM |
Re: Printer hangs before printing February 04, 2016 03:06PM |
Re: Printer hangs before printing February 04, 2016 03:10PM |
I have edited it and it work perfectly now thanksQuote
justcurious
Yoko
i think this is the problem in slic3r
M109 S{print_temperature}
there is no variable in Slic3r called "print_temperature".
You may use these in your custom G-code:
M104 S[first_layer_temperature] ; set extruder temp
M109 S[first_layer_temperature] ; wait for extruder temp
