Ghost X axis command
Posted by Reaper1278
April 05, 2016 07:46PM
Where in the world is this last command generated? Its going to break my printer! Please see picture for reference.
open | download - Screen Shot 2016-04-05 at 4.32.43 PM.png (513.6 KB)
Re: Ghost X axis command
April 05, 2016 08:29PM
I just deleted ALL the G code and that movement still shows. What gives?
April 05, 2016 11:51PM
I've not used Slic3r embedded in Repetier-Host but it looks like it's coming from the End G-Code (Printer Settings --> Custom G-Code --> End G-Code in the standalone version of Slic3r). If you've found that parameter and it's not there, R-H also has a habit of inserting its own start/end g-codes when you run something not off the SD card or when you load something to the SD card with default settings. As I recall I got those out using the Preferences menu.
April 06, 2016 11:16AM
Used the standalone of Slic3r and there is nothing instructing such a move. I load that code into Repetier and it shows up again. Definitely a glitch with Repetier.
