No slowdown
May 05, 2016 03:11AM
I am using the actual developer version of Slic3r from Github (510ca9f).
The last Commit was "Merge pull request #3303 from hyperair/fix-cooldown"
I have enabled "Auto cooling" and slow down printing if the print time is below 20s with minimum print speed of 1mm/s.
With this configuration the print slows down to approximately 20s on small objects if I am using Slic3r 1.2.9.
But if I am using the above mentioned actual developer version there is no slowdown.
Re: No slowdown
May 06, 2016 11:42AM
what are you printing with these settings ?
P3steel DXL, with Due/RADDS/Raps128 dual Wade's extruder
Re: No slowdown
May 07, 2016 02:44AM
The effect doesn't depend on the object. Even with a cube I have no slowdown.
The older version 1.2.9 (with the nasty gap infill bug) or some older developer version slows down as expected.
Re: No slowdown
May 07, 2016 03:51AM
the effect does mater on the object, as I reaf it it will only slow down when the printing time gets below the threshold
Re: No slowdown
May 07, 2016 04:22AM
Yes, I know this. smiling smiley
I only expect a slowdown if the time for a layer is lower than then given threshold.
OK, example:
- My threshold is 20s.
- If the layer time is around or above 20s there is no slowdown and this is correct and expected.
- If the expected layer time is lower than 20s (e.g. 3s), there should be a slowdown, so the effective layer time is around 20s.
With 1.2.9 and an older dev-version (A) it works as expected and described.
With the actual dev-version (B ) there is no slowdown.
example:
- small object (cube with one perimeter an no infill)
- auto-cooling disabled: layer time 2-3s for A and B.
- auto-cooling enabled: layer time for A: around 20s, layer time for B: 2-3s
Edited 1 time(s). Last edit at 05/07/2016 04:23AM by Wowbagger.
Re: No slowdown
May 10, 2016 02:54AM
Does nobody have the same problem with the actual developer version of Slic3r from Github (510ca9f).?
It is easy to replicate, even as dry run:
- cube with 20mm size
- perimeter:1, no infill
- speed for perimeter 60mm/s
- one layer is 80mm long
- without auto cooling:
layer time around 2s
with auto-cooling (slow down if below 20s, min print speed 1mm/s):
layer time is again around 2s (no slow down), but should be around 20s.
Re: No slowdown
May 12, 2016 08:07AM
OK, I have posted a issue on Github and we found the bug.
The slowdown is only working, if "verbose output" for the GCode is enabled.
