Slic3r crashes on W10
Posted by Replace
August 23, 2016 08:10AM
AS my Macbook is currently under repair,
I installed Slic3r 1.2.9 on my new HP W10 laptop.
But every 2nd or 3rd load, it will crash.
1st load after start will always be good.
When I add, or add after delete, it will crash often.
Is there a known issue with either the HP of the W10 ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Slic3r crashes on W10
August 23, 2016 10:52AM
I see this crash issue a lot on my Windows 10 systems. I turned off the background processing under preferences and the crashing has gone away. It does take a little longer to export the gcode, but I'll take that over the crashing any day of the week.
August 23, 2016 12:06PM
Ok,
that is a good tip.
I will deselect that option for a chance... thnks
August 23, 2016 05:08PM
This bug has been around for a long time. The following seems to reduce its occurrence:
1. If you are upgrading form an older version of slic3r, delete all the configuration info from the old version and re-enter it.
2. After slicing a model, exit slic3r before you load and slice another model.
3. Set it to run in single-threaded mode.
I got so fed up with it crashing that I bought S3D. But I occasionally still use slic3r.
October 07, 2016 06:04AM
Please try with the semi-official Slic3r builds by LoH
[bintray.com]
or with our Prusa3D builds:
[github.com]
The official Slic3r builds are outdated.
