Generate G-Code for Perimeter only
Posted by b2boarder
October 27, 2016 09:09AM
Here's what I'm trying to do...
Step 1: Lay down a few layers of filament with extruder 1.
Step 2: Come back with a cutting tool (extruder 2?) and and run it along the perimeter of the layers that I just had layed out.
How would I generate code for only the perimeter of the first layers that I layed down in step 1?
Re: Generate G-Code for Perimeter only
October 28, 2016 12:23AM
Ambitious. The software isn't designed for this but you might be able to slice twice and manually combine the gcode. Settings for the second slice would be:
Custom STL with the profiles offset in X and Y (adding material) by half the diameter of your cutter
No-extrusion gcode style
One perimeter, 0% infill
Microscopic but nonzero external perimeter extrusion width (Zero would set it to automatic)
You might have to add a G1 to some specific X and Y coordinates that put the cutter on the same side of the part as the perimeter start so the travel move at the beginning doesn't cross the part.
