Making Slic3r use M140 instead of M190 January 08, 2017 08:19AM |
; generated by Slic3r 1.2.9 on 2017-01-08 at 13:57:54 ; external perimeters extrusion width = 0.30mm ; perimeters extrusion width = 0.30mm ; infill extrusion width = 0.30mm ; solid infill extrusion width = 0.30mm ; top infill extrusion width = 0.30mm M107 M190 S40 ; set bed temperature M104 S225 ; set temperature
Re: Making Slic3r use M140 instead of M190 January 08, 2017 04:50PM |
Re: Making Slic3r use M140 instead of M190 January 09, 2017 04:21AM |
Re: Making Slic3r use M140 instead of M190 January 09, 2017 07:43AM |
Re: Making Slic3r use M140 instead of M190 January 21, 2017 11:36PM |
dmould
As soon as you use one of the place-holders in your custom G-code (e.g. "[first_layer_bed_temperature]"), Slic3r will no longer add its own command for that parameter.
Dave
