Gap between perimeter 1 and 2
March 12, 2017 04:53AM
I am facing a problem with my prints using slic3r. When I create the g-code with slic3r, there is a visible gap in the print preview between perimeter one and two (counted from the inside) which is also visible in the print:
The print preview also shows the gap:
When I slice the same stl with cura engine, this gap is not visible:
Is this a setting I messed up? I know the infill overlay feature, it is set to 15%, but is has no influence at this point.
What can I do against this gap?
Re: Gap between perimeter 1 and 2
March 14, 2017 12:00PM
Perhaps this is an issue with the hex infill? Did you try other infill options?
March 14, 2017 12:34PM
You should tell the Slic3r version you are using and provide your config file, otherwise people will not be able to help you.
March 15, 2017 01:59PM
Thank you for the replies, here a screenshot of the rectilinear infill, same thing.
I also attached the config file
Slic3r Version 1.2.9
open | download - config.ini (3.4 KB)
March 21, 2017 12:14PM
Change to Prusa-Fork of Slic3r - they solved many Problems with Infill & Thin Walls, and have many new cool Features: : Newest Prusa-Slic3r
"1.2.9 - stable" was never stable, nor was it usable error free.
March 22, 2017 04:55AM
Thank you Dancer, I will give it try with the prusa fork, I was checking at slic3r homepage for a newer revision, but 1.2.9 was the latest one
