Slic3r Generated G-code Files are Truncated When Printed April 30, 2017 04:24AM |
Re: Slic3r Generated G-code Files are Truncated When Printed May 01, 2017 03:11AM |
Re: Slic3r Generated G-code Files are Truncated When Printed May 01, 2017 03:29AM |
o_lampe
It seems the firmware doesn't allow to print negative coordinates and truncates the moves internally.
How did you set the bed origin in slic3r and Cura? Are they the same? ( eg. both have the bed center at 0,0 checked/unchecked ? )
Re: Slic3r Generated G-code Files are Truncated When Printed May 02, 2017 04:08AM |
Re: Slic3r Generated G-code Files are Truncated When Printed May 03, 2017 07:46AM |
Re: Slic3r Generated G-code Files are Truncated When Printed May 03, 2017 09:00PM |
dmould
First see whether the issue is with Slic3r or your controller. Make a small print file using a text editor (or send the commands manually):
G1 X0 Y0
G1 X200 Y0
G1 X200 Y260
G1 X0 Y260
G1 X0 Y0
If that results in the head moving along each edge of the bed, the issue is with Slic3r. If not, it is with your controller (disable limiting via "M564 S0" command or set limits set using M208 [reprap.org])
Dave
Re: Slic3r Generated G-code Files are Truncated When Printed May 04, 2017 12:13PM |
