I have objects (open bent cylinder, lying horizontal ) that I will cut on the buildplate by the cut function.
The object is 17.9 mm high and I perform the cut at 8.9 mm with 'keep and rotate the other half.
Now I expect both halves to be on the build plate, starting at both sides of the hole in the cylinder.
but only one side of the cut half touches the plate.
The other side starts printing after layer 5 or even more......
So my print does not come out nice.
Any clue what goes wrong ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
