How to do home & bed leveling AFTER heating ?
Posted by Andke
August 12, 2017 03:47PM
My start GCODE contains
G28
G29
This works like:
While the head is docked (cannot ooze):
-the BED is heated, (takes 4-5 minutes)
-the extruder is heated, ~1.5 minutes.
-the printer does homing (oozing)
-and bed levelling. (oozing)
how can I configure a smarter script like:
1.- Turn on bed (do not wait - using the Slic3r preset, not just fixed tamperature)
2.- do homing
3 - do levelling
4 - go back to docking position (I have code for that)
5 - heat extruder (and wait - using the Slic3r preset, not just fixed tamperature)
6 .. print
this would save time, and prevent any undocked oozing.
Re: How to do home & bed leveling AFTER heating ?
August 13, 2017 09:38AM
list of slic3r placeholders [mauk.cc]
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
M140 S[first_layer_bed_temperature] ;set bed temp fast
G28 ;home all axis
G1 Z6 F1000 :raise Z B4 lvl bed
G29 ;lvl bed
G0 Z5 F1000
G1 X0 Y0 F3000
M190 S[first_layer_bed_temperature] ;wait for bed
M109 S[first_layer_temperature_0] ; Wait for all used extruders to reach temperature
G92 E0
Optional priming line in needed, insert after the G92 E0
G1 X5 Y5 Z0.25 F1000.0 ; go intro start pos
G1 X60.0 E11.0 F600.0 ; intro line
G1 X100.0 E21.5 F800.0 ; intro line
G92 E0.0 ; reset extruder distance position
G1 E-1
Edited 5 time(s). Last edit at 08/14/2017 06:37PM by obewan.
August 13, 2017 04:55PM
Thank you ! - great ! smiling smiley I did not know there was a way to make such change in behavior.
August 14, 2017 02:24AM
G1 X0 Y0 F{travel_speed}
this line won't work correctly, as it uses waved brackets. ( looks like a line from Cura? )
August 14, 2017 10:03AM
well spotted, the command is correct but typed the wrong brackets.
