Incorrect perimeter
Posted by frankvdh
Incorrect perimeter
October 22, 2017 03:43AM
When I slice the linked STL with Slic3r, it doesn't generate a perimeter around the entire set of objects.
This applies to both v1.2.9 and the latest Linux build Slic3r-1.3.0-dev-451f2e3-x86_64.AppImage. Workaround is to split the file into multiple objects using the Split command in Slic3r. But without doing a preview, there's no way to know that the split is needed. In case it's relevant, the STL was generated using OpenSCAD (version 2017.10.18.nightly (git 995fac0).
[www.dropbox.com]
Re: Incorrect perimeter
October 22, 2017 07:24AM
I get exactly the same thing with Simplify3D even though it rearranged the parts on the build plate. The reason is that the part that is out of the outline is sitting slightly above the bed and doesn't start printing until the second layer. Check your OpenScad model.
Edited 1 time(s). Last edit at 10/22/2017 06:14PM by dc42.
October 22, 2017 02:23PM
Ahhhh... thanks. Makes perfect sense. smiling smiley
