gcode that is generated question... December 10, 2017 05:47PM |
; generated by Slic3r 1.2.9 on 2017-12-10 at 17:41:26 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.48mm ; infill extrusion width = 0.48mm ; solid infill extrusion width = 0.48mm ; top infill extrusion width = 0.48mm M107 M190 S60 ; set bed temperature M104 S195 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S195 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ...
Re: gcode that is generated question... December 10, 2017 10:43PM |
Re: gcode that is generated question... December 11, 2017 06:52AM |
IMBoring25
As long as your Z coordinates correspond to how far away the nozzle is from the bed it's fine.
G1 Z5 F5000
G1 Z-5 F5000which I'm not sure would do anything since the Z axis has been zeroed and there would be no additional movement it can make to offset the bed.
Re: gcode that is generated question... December 11, 2017 09:17AM |
Re: gcode that is generated question... December 11, 2017 10:04AM |
