Z full steps/mm and layer height
Posted by eavo
December 18, 2017 04:57PM
Hi guys,
setting the Z full steps/mm in Printer Settings I have some troubles with the layer height.
If I set a 0.2 layer height Slic3r makes each layer of 0.16 mm. Why?
p.s. I'm using Slic3r-master.2017.12.15.1558.54205b7.64bit
Re: Z full steps/mm and layer height
December 18, 2017 05:30PM
Under Printer Settings>General, did you put a nonzero value in the "Z Full Steps per mm" box? If so, slic3r is using full step layer thickness that is closest to your set layer thickness.
If you don't want it to do that, set the entry to zero.
December 19, 2017 04:35AM
Yes, I set this value to 25. In this way a layer height of 0.2 mm corresponds to 5 full steps and I don't understand why slic3r makes layers of 0.16mm.
December 19, 2017 09:28AM
Hmmm. It sounds like it isn't working right. I'd set it to zero and use manual control of layer thickness.
January 24, 2018 11:34AM
New builds seem to work well.
