Slic3r maximum layer height
Posted by DasK
January 19, 2018 04:21AM
i have an hacked DaVinci printer where i loved slic3r to slice my models.
Now im building a big extruder where i need a layer height of 4mm but cant get that value to work in setting.
Do you have any suggestions?
Kind regards
Sebastian
Re: Slic3r maximum layer height
January 19, 2018 07:41AM
How big is the nozzle? I think slic3r limits layer height based on nozzle diameter. You can't print in 4 mm layers with a 3 mm diameter nozzle, for example.
January 20, 2018 03:07AM
In the printer setup menu you can set min- and max- layerheight and nozzle diameter as well. Did you try that?
February 28, 2019 02:38AM
hi.
this is also my problem. did you find the solution?
i would appreciate your answer.
Edited 1 time(s). Last edit at 02/28/2019 02:39AM by Saeed_gch.
