Lithophanes after slicing not on the bed
Posted by onit12
June 12, 2018 04:30AM
Hi there,
i am trying to print some lithophanes but have weird problems with slicing in Slic3r.
After rotating the object around the x-axes and slicing it with the settings from here, the object is not on the printer bed any more.
I dont`know if there is any setting?
Any ideas?
Thanks
Tino
open | download - img_018.bmp (635.7 KB)
Re: Lithophanes after slicing not on the bed
June 13, 2018 03:09AM
Usually the part drops down to the surface.
Maybe you have to use the "cut" function after rotating and only keep the upper part.
June 14, 2018 10:21AM
Yes, the part is on the surface till rotating and slicing it, then it`s in the air. Before rotating and slicing everything is ok.
I will give it a try with cutting the lower part.
Is this a bug?
June 15, 2018 03:15AM
Maybe you have to enable the 'detect thin walls' option?
June 15, 2018 08:37AM
can you share the stl
June 27, 2018 01:49PM
With the ‚detect thin walls‘ option it seems to slices ok, I will soon have a try. White PLA is out sad smiley
