Help needed - Uneven segment lengths on circles June 23, 2018 09:47AM |
Re: Help needed - Uneven segment lengths on circles June 23, 2018 04:50PM |
Re: Help needed - Uneven segment lengths on circles June 23, 2018 06:02PM |
dc42
Uneven segment lengths within arcs don't cause issues with pressure advance, but uneven extrusion rates do. Try putting the XYE values into rows on a spreadsheet, calculate the XY distance moved in another column, then divide the extrusion amount by that to get the extrusion rate. Then you can see whether it is consistent or not.
Re: Help needed - Uneven segment lengths on circles June 24, 2018 01:45AM |
Re: Help needed - Uneven segment lengths on circles June 24, 2018 02:23AM |
o_lampe
If possible, I'd suppress pressure advance below a certain track-length in Firmware. Is that a possibility? Would it help you, Mike?
Re: Help needed - Uneven segment lengths on circles June 24, 2018 03:09AM |
If it's not you, it must be 'leadinglights', because I often confuse you...Quote
BTW, who's Mike?
Sorry
