slic3r 1.3 crashing on support generation
Posted by bwasserman1
September 24, 2018 06:37AM
I have tried the latest versions of slic3r 1.3X and have found issues when it comes to using supports. The other features work reasonable well and generate code without any crashes. However, when I set slic3r to generate support, for the same file, the program always crashes.
I think slic3r is a grat program and I have used it since I started 3d printing. It is simple and reliable. But since 1.29 this has not been the case.
Any help would be appreciated.
Thank you
Re: slic3r 1.3 crashing on support generation
September 26, 2018 08:43PM
I am having the same problem. I'm using Slic3r via Repetier Host v2.1.3. It says it is using Slice3r "v1.3.0 or higher"
Any help would be greatly appreciated!
April 22, 2019 09:26AM
Hi, I also encounter the same problem with Slic3r, if I apply supports to the object instead of stopping the program in an anomalous way instead it creates the gcode for me, but wrong because checking the layers that some of them have developed are missing ... I hope that someone can give us a solution, thanks in advance.
