Problems in fusing internal structure to thin walled skin
September 27, 2018 11:03AM
I am trying to create a wing section using a single perimeter skin and a lattice of ribs inside. The problem I have is getting the ribs to fuse to the inside of the skin, without being visible on the outside.
I have attached to screenshots showing a section of the wing. If I leave a gap of 0.1 mm between the ribs and the inner surface of the skin the ribs do not fuse well to the skin. If this gap is reduced to 0.05 mm the ribs fuse to the skin but create lines on the outer surface of the skin which affect the surface finish. I know that it is possible to have the ribs fuse with a smooth outer surface as 3dlabprints manage to do this, but I do not know the slic3r setting to get around my problem.
I would be grateful for any help you can give.
I am using a Prusa I3 MK2 printer and Slic3r Prusa edition Version 1.39.1 with a nozzle diameter of 0.4 mm.
open | download - Capture2.JPG (31.9 KB)
open | download - Capture.JPG (33.5 KB)
Re: Problems in fusing internal structure to thin walled skin
September 27, 2018 01:14PM
I would make a solid profile and set the infill to a low value. But with a single perimeter you have to be lucky, that the slicer can draw the track without retraction(s).
You can also try to print it in 'vase' mode.
September 27, 2018 01:56PM
The native infill does not provide an acceptable strength / weight ratio. The wing has to be very light but with adequate resistance to bending and torsional loads.
If you check out 3dlabprints you can see that they have gone to a lot if effort to achieve this and that is what I am trying to emulate.
Edited 1 time(s). Last edit at 09/27/2018 01:57PM by U400666.
September 27, 2018 02:53PM
I've never seen a single wall print that didn't show the internal fill. You usually have to use at least 3 perimeters to make the infill "disappear".
Molten plastic shrinks as it cools, and that cause single thin wall strands to pull the the infill verticals toward each other. Since they are less likely to move because of bulk, the thin wall tends to move instead. On a flat area it's less of a problem, but a curved single wall shell will tend to straighten as the plastic shrinks, and that will make the infill very visible.
You can try tweaking the overlap between the outer wall and the infill, but if you make it too small, you lose bond strength and end up with a wing that looks nice but isn't very strong.
Edited 1 time(s). Last edit at 09/27/2018 02:56PM by the_digital_dentist.
September 27, 2018 03:25PM
Check out the 3dlabprints examples on their website. The ribs are visible when you hold the wing up to light, but the exterior surfaces are smooth, I have printed examples. They are single perimeter and they are strong.
I have been playing with the gap see examples I posted. 3dlabprints use simplify 3d and I wonder if this is more tunable in terms of the overlap. With slic3r I either have a gap and little fusion or the ribs visible and feelable on the extrenal surface.
September 27, 2018 04:14PM
To date I have beem controlling the gap in my CAD program. The gap that comes out in Slic3r seems to be more of an on / off thing. I wonder if there is a setting to allow a bit more extrusion at the top and bottom of the ribs to fill the gap.
Edited 1 time(s). Last edit at 09/27/2018 04:15PM by U400666.
September 27, 2018 04:21PM
I have printed several of the 3dlabprint planes,i never managed to get slic3r to slice the internal structure correctly
You get muchh better results using cura 3.4.1
Draw the ribs as a closed rectangle and the skin around the outside, see example
September 27, 2018 05:25PM
Thanks obewan.
Does this approach give a smooth outside surface?
September 28, 2018 06:09AM
I get results like this
September 28, 2018 06:48AM
Looks similar to what I got using their prepared g-codes.
I am trying to design from scratch and slic3r is not helping.
I am just playing with Cura now and it looks encouraging. I will try a test print tonight.
Thanks for your help.
September 28, 2018 08:05AM
The surface is smooth, what you see is the transparency of that particular pla showing the internal structure.
I printed a mig15 in red pla that does not show the internal ribs
September 28, 2018 09:47AM
Thanks.
Did you slice this example or was it a prepared g-code?
If you sliced it would it be possible to get your cura settings?
September 28, 2018 05:00PM
cura 3.4.1 profile attached (i hope) this is for a prussa I3 mk2 clone with direct drive extruder,
open | download - cura341_single wall.curaprofile (2.1 KB)
September 29, 2018 05:19AM
Thanks for the settings file obewan, I will give this a try.
I had an initial go with cura and found that I got better results with the ribs bonding but some of the skin had gaps in it when printed. With Silc3r I would fix this with thin wall detection, not sure what the cura version is but hopefully your settings file will capture this.
September 30, 2018 02:41PM
Hi obewan,
The Cura profile almost does what I need, the print quality is very good but the skin is being printed double thickness at 0.8 mm whereas my model has 0.4 mm.
Bit surprised as you have the wall line count set to 1 and the nozzle on my Prusa is 0.4 mm.
Any help would be very welcome.
September 30, 2018 05:52PM
Strange, in cura it shows only 1 wall when i slice a wing part.
Can you attach or send me your stl that you tried.
September 30, 2018 06:10PM
Hi Obewan,
I have attached a couple of stl files which I have been using, these are just test pieces to try to get the method sorted out.
When I slice these in Cura and look in layer view it looks to me like a single perimeter skin, but it prints with 2 perimeters. I may be misreading the Cura images as I am new to this program.
open | download - Wing_Skin_0.4_Gap_0.0 (Meshed).stl (119.6 KB)
open | download - Wing_Skin_0.4_Gap_0.05 (Meshed).stl (298.3 KB)
October 01, 2018 07:41AM
I think i see the problem, you are drawing the skin in the cad program with a line width,i think the 3dlab guys draw a skin with no width.
October 01, 2018 08:15AM
I am creating the skin in 3d CAD by importing an aerofoil, extruding it and creating a thickness of 0.4 mm. Not sure how to do this with zero thickness I am pretty new to CAD.
The skin came out well in Slic3r at 0.4 mm but my first attempts in Cura had missing patches where the nozzle did not seem to extrude well.
October 01, 2018 09:17AM
I suppose I could extrude the aerofoil with no thickness but can I create an stl file with this? I can give it a go.
Edited 1 time(s). Last edit at 10/01/2018 10:40AM by U400666.
October 03, 2018 01:05PM
I think that I am making some progress with getting Cura set up to produce a single perimeter aerofoil print, but I have one remaining problem.
I have attached a photo of the first layer which I stopped from printing before the ribs were printed. The aerofoil suction surface is printed first, nose to tail. When the pressure surface print is started, again nose to tail, the material does not flow for the first part and this is leaving gaps. I would like the whole aerofoil skin to be printed in one pass, but do not know the settings to force this to happen.
The skirt prints fine so it must be a problem with extrusion / retraction when the aerofoil print begins. I tried ticking the optimize wall printing order and the outer before inner walls boxes, but these had no effect.
Kelp would be much appreciated.
open | download - Daves_Phone_Pictures 784.jpg (63 KB)
open | download - Capture.PNG (105 KB)
