I have designed a 2 part project box that has a slanted top for a lcd display. I designed it using Fusion 360. I do not have much experience using supports. I prefer to design to print without supports.
I print using Repetier Host, and slice with slic3r or slic3r PE contained in Repetier Host.
The link below will take you to a 3d view of the top of my project box.
https://a360.co/2FNM6xf
How can I divide the case top up to print without supports, or what would be the slic3r settings for easily removed supports? I can cut the top into 2 parts fusion at an angle where the slant meets the flat bit.
How would you do it?
Edited 2 time(s). Last edit at 03/30/2019 12:10PM by chucketn.
