I often use a layer dependant pause, to change the filament color.
But now I see strange behaviour with multiple objects on the build plate.
.I., this code : {if [layer_num] == 7} @pause;
This will pause the printer after completion of layer 6.
This works ok with slicing any single object.
Also, if I load an object and I hit the + (more), the printer will pause after layer 6, regardless how many copies I make with the + function.
But: If I load multiple objects (not copy them), the printer will pause earlier.
If I load 2 items, it will pause after layer 3
I I load 5 objects, it will pause after layer 1.
How does this work with multiple objects ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
