Hi all
I want to slice multiple objects 0.obj 1.obj 2.obj... using the command line only;
And I want to attribute for each object an extruder for printing.
I have been able to do this via the GUI just fine however, thes models are much heavier and the command line is faster based on what I've experienced.
The syntax that I've tried so far goes as:
slic3r -j 8 --no-gui --load config_all.ini --support-material-extruder 2 --support-material-interface-extruder 2 --dont-arrange --perimeter-extruder 2 --infill-extruder 2 --solid-infill-extruder 2 --perimeter-extruder 1 --infill-extruder 1 --solid-infill-extruder 1 --merge 0.obj 1.obj
But this results in the combined structed printed using extruder 1 only. Ps. specifying the extruder for the support works just fine.
Many thanks in advance
