Hello together,
I would like to use a CNC milling machine with XYZ control as a frame construction for my 3D printer. I intend to print a cube sample with an edge length of 30 cm. For this purpose, the frame construction should have the external dimensions: X=Y=65 cm, Z=50 cm. Is it possible to use an existing slicer program like Slic3R, Prusa Slicer or Cura for the axis control ? Has anyone had experience with this ?
Thanks in advance !
Best regards,
Beyza
