g-code leads to: Print doesn´t stop when printhead is traveling
July 07, 2021 06:43AM
Hey everyone,
I am new to 3D-printing and worked with slic3r to create a simple cylinder with a grid structure. The problem I am having now is that when the g-code is generated somehow the instructions for turning off printing when travelling to a new location are missing. I created a commented g-code (both attached, settings for the print may vary), in which you can see where the extruder retracts, so I could manually input the commands but that is too inconvenient.
Can somebody help?
open | download - 9 Zylinder.gcode (24.5 KB)
open | download - Zylinder Comented version.gcode (32.5 KB)
Re: g-code leads to: Print doesn´t stop when printhead is traveling
July 11, 2021 08:22PM
I think most slicers have options for retraction. I know Slic3r and Prusaslicer have it. If using that look under Printer Settings/Extruder
July 13, 2021 08:12AM
Thank you for your answer. smiling smiley
I searched in the print & printer settings and found options for retraction but nothing about turning the print on/off.
So the print still doesn´t stop when the printhead is retracting. sad smiley
(And yes, I am using Slic3r)
Edited 1 time(s). Last edit at 07/13/2021 08:12AM by Klara.
