Greater layer hights 5mm < November 04, 2021 11:41AM |
Re: Greater layer hights 5mm < July 15, 2022 08:01AM |
Re: Greater layer hights 5mm < July 15, 2022 02:11PM |
Re: Greater layer hights 5mm < July 15, 2022 03:56PM |
Admin Registered: 18 years ago Posts: 14,176 |
Re: Greater layer hights 5mm < September 01, 2022 11:02AM |
Re: Greater layer hights 5mm < September 01, 2022 03:34PM |
Re: Greater layer hights 5mm < September 01, 2022 03:37PM |
musztard
Thank you for the replay.
I ended up using rhino and grasshopper (to extract curves) since Slic3r couldn't meet my needs in the project. I had failed in my first simulation but luckily i found out what the mistake was.
In a week i will be running another tests with my robot and RoboDK, so i can let you know about the results if anybody will still be interested.
Re: Greater layer hights 5mm < September 02, 2022 02:56AM |
However Rhino, since it is more of a surface modelling software it is a bit different to programs like Fusion and is still causing me troubles.
Also it is possible to upload your custom shapes into it right now. Could you give me a hint on how to use the cooridantes to come up with gCode?|
Re: Greater layer hights 5mm < September 09, 2022 02:18PM |
