Slic3r Conditional G-Code fail
Posted by scumari
October 19, 2024 03:21AM
Hi
I am trying to get the following condition working:
{if [layer_num] == 0}{if [next_extruder] == 1}G1 E16 F1200
It seems that layer_num is always zero!
What can be wrong here?
Thanks in advance, Rick
Check [www.scumari.nl]
VDX
Re: Slic3r Conditional G-Code fail
October 20, 2024 04:55PM
... check where or if [layer_num] is updated or use the correct variable, if it's different.
Forgot -- is it the correct scope? otherwise you wouldn't get updates ...
Edited 1 time(s). Last edit at 10/20/2024 04:57PM by VDX.
Viktor
October 21, 2024 02:09AM
Thank you, [layer_num] variable not in 'Tool change G-Code' scope.
VDX
October 21, 2024 03:04AM
... it's not a proper style, but you can try with declaring it "globally" ... or search, if you find another methode to get the updates through ...
Viktor
