It actually starts on the last infill layer. So there is 3 solid layers there. It just starts on the last infill layer. I checked the model carefully and fixed a slight error, but it still does it. It also does it with Cura and Prusa slicers, so it has to be something in the model, but the model looks perfect now. Then again, Cura is doing something else beside this that the others are not. Rotating it doesn't change it. Up to the last layer of infill everything is fine.
OK, it has to do with the layer height. I changed to my large model and it did not do it. Then I made the large model layer height the same as my normal and it was there. Why that affects it is truly a mystery to me. I changed my normal from 0.2 and 0.3 to 0.25 and 0.3 and it is gone. It is still a mystery as to why......
Edited 3 time(s). Last edit at 10/25/2025 08:15PM by dustinoff.
