compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware February 10, 2012 08:46AM |
Thank you for showing me repetier! It looks very promising. I have downloaded it and tried compiling it, but it still gives a few errors, though far less than sprinter did. If someone could please point me to a place where I can get some help with this that would be great, thanks.
these are the errors in case anyone knows whats going on
In file included from /Configuration.h:32:0,
from Commands.cpp:22:
c:\documents and settings\quentin\desktop\mpide-0023-windows-20111221\mpide-0023-windows-20111221\hardware\pic32\compiler\pic32-tools\bin\../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/include/avr/io.h:4:2: error: #error ******** This sketch or library uses AVR-specific code that may not work with the chipKIT platform. See this forum for more information on porting code to chipKIT [www.chipkit.org/forum/viewforum.php?f=7] ********
In file included from /gcode.h:19:0,
from /Reptier.h:28,
from Commands.cpp:23:
c:\documents and settings\quentin\desktop\mpide-0023-windows-20111221\mpide-0023-windows-20111221\hardware\pic32\compiler\pic32-tools\bin\../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/include/avr/pgmspace.h:4:2: error: #error ******** This sketch or library uses AVR-specific code that may not work with the chipKIT platform. See this forum for more information on porting code to chipKIT [www.chipkit.org/forum/viewforum.php?f=7] ********
In file included from /Reptier.h:29:0,
/fastio.h:2554:2: error: #error pins for this chip not defined in arduino.h! If you write an appropriate pin definition and have this firmware work on your chip, please submit a pull request
In file included from Commands.cpp:24:0:
/Eeprom.h:22:24: fatal error: avr/eeprom.h: No such file or directory
compilation terminated.
Re: compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware February 10, 2012 10:15AM |
Re: compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware February 10, 2012 05:15PM |
Re: compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware February 10, 2012 07:22PM |
Re: compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware February 19, 2012 05:24PM |
