Homig & Go to dump area February 15, 2012 05:12PM |
Re: Homig & Go to dump area February 16, 2012 12:43PM |
Re: Homig & Go to dump area February 17, 2012 04:39AM |
Re: Homig & Go to dump area February 19, 2012 06:22AM |
Re: Homig & Go to dump area February 19, 2012 06:56AM |
//// Endstop Settings #define ENDSTOPPULLUPS 0 // Comment this out (using // at the start of the line) to disable the endstop pullup resistors // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. //set to true to invert the logic of the endstops #define ENDSTOPS_INVERTING false //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
Re: Homig & Go to dump area February 19, 2012 07:16AM |
//// Endstop Settings #define ENDSTOPPULLUPS 1 // Comment this out (using // at the start of the line) to disable the endstop pullup resistors // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. //set to true to invert the logic of the endstops #define ENDSTOPS_INVERTING false //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here ----- // Inverting axis direction #define INVERT_X_DIR false #define INVERT_Y_DIR false #define INVERT_Z_DIR false //// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 //If true, axis won't move to coordinates less than zero. #define min_software_endstop_x false #define min_software_endstop_y false #define min_software_endstop_z false //If true, axis won't move to coordinates greater than the defined lengths below. #define max_software_endstop_x true #define max_software_endstop_y true #define max_software_endstop_z true // You can disable endstop checking for print moves. This is needed, if you get sometimes // false signals from your endstops. If your endstops don't give false signals, you // can set it on for safety. #define ALWAYS_CHECK_ENDSTOPS true // maximum positions in mm - only fixed numbers! #define X_MAX_LENGTH 200 #define Y_MAX_LENGTH 200 #define Z_MAX_LENGTH 100
Re: Homig & Go to dump area February 19, 2012 07:39AM |
Re: Homig & Go to dump area February 19, 2012 08:02AM |
Re: Homig & Go to dump area February 19, 2012 08:18AM |
Re: Homig & Go to dump area February 19, 2012 08:36AM |
Going to the positive side is never a problem. Thats understandable, because no endstop is tested in that direction.
If I understand you right, if you enable the printer with switches pressed, you can go to the positive axis and come back?
If you start somewhere else, homing does nothing not even going to the positive dir for a short time and going back?
As going to the right is no problem i would expect at least the 5mm move to succeed.
If I unterstand everything right, the big question is why the switches send the correct signal, when you start with them triggered and don't work if started anywhere else.
Re: Homig & Go to dump area February 19, 2012 09:04AM |
Re: Homig & Go to dump area February 19, 2012 09:48AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Homig & Go to dump area February 19, 2012 10:43AM |
Re: Homig & Go to dump area February 19, 2012 11:31AM |
Re: Homig & Go to dump area February 19, 2012 12:59PM |
