File not found exception when using Skeinforge file postfix option
Posted by Karl_Williams
March 18, 2012 12:46PM
I'm running Repetier host V0.40 on Windows 7. If I add a file postfix in the skeinforge setup window then a file not found exception is generated when skeinforge is finished slicing and repetier tries to load the gcode. The gcode file is generated and it can then be loaded manually afterwards:
C:\repetier-work>dir
Volume in drive C is OS
Volume Serial Number is 1E11-6114
Directory of C:\repetier-work
18/03/2012 12:17 PM
open | download - slic3r-error.jpg (327.1 KB)
open | download - slic3r-error-2.jpg (268.4 KB)
Re: File not found exception when using Skeinforge file postfix option
March 18, 2012 04:43PM
I think you misunderstood the settings for skeinforge. You need to enter the namechanges that skeinforge does to the stl file, so the host can find the generated file after the slicingis finished. As you already stated you skeinforge setings need a blank postfix for this. You can change that in the skeinforge setup, thats why you need a way to tell it to the host.
March 19, 2012 12:54AM
Thanks for clarifying that. If the 'Add export suffix' box is checked in the export tab in Skeinforge then _export needs to be in the postfix.
I should have read the manual LOL.
