While trying a couple of tests with Skeinforge (Slic3r is so much easier ...!), I found the following :
In the export options in Skeinforge, one can activate or deactivate the filename postfix; and the Repetier-Host Mac user has to change the corresponding setting in the Preference panel / Slicer / Skeinforge window.
If the filename postfix is deactivated, it's impossible to change it in the Repetier-Host. When the "_export" text is deleted in the text field, it will come back when you select another text field. And since that field is not recorded in the preferences plist file, the next time the host is launched, the G-code file can't be found.
I suggest to record that field and the g-code extension field as well in the plist file.
See the attached picture.
Thks
open |
download -
(94.5 KB)
