Connection Problem May 10, 2012 01:10PM |
Re: Connection Problem May 10, 2012 01:29PM |
Re: Connection Problem May 10, 2012 02:02PM |
Re: Connection Problem May 10, 2012 03:00PM |
Re: Connection Problem May 10, 2012 03:25PM |
Re: Connection Problem May 10, 2012 04:23PM |
Re: Connection Problem May 11, 2012 05:10PM |
Re: Connection Problem May 12, 2012 02:04AM |
19:07:27.529 : FIRMWARE_NAME:RepetierVirtualPrinter FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:1 07:59:00.298 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:00.476 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:01.303 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:03.307 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:05.310 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:06.312 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:07.313 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:08.315 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:11.319 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 07:59:15.328 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgsThis message indicates a connection wrong hardware setting. Then I switched back and tried to connect. The OS said ok, but I had the x commands waiting, so I wasn't getting any feedback from the printer. After hitting the printer reset and waiting 5 seconds the connections was established.
Re: Connection Problem May 12, 2012 02:34PM |
Re: Connection Problem May 14, 2012 11:50AM |
Re: Connection Problem May 14, 2012 12:01PM |
Re: Connection Problem May 14, 2012 12:34PM |
Re: Connection Problem May 14, 2012 04:20PM |
