compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware
Posted by ryan_prof
February 10, 2012 08:46AM
Hi this is a post from a newbie(Quentin T.) whom posted the following in a different topic, I thought I'd put it in the right section:
Thank you for showing me repetier! It looks very promising. I have downloaded it and tried compiling it, but it still gives a few errors, though far less than sprinter did. If someone could please point me to a place where I can get some help with this that would be great, thanks.
these are the errors in case anyone knows whats going on
In file included from /Configuration.h:32:0,
from Commands.cpp:22:
c:\documents and settings\quentin\desktop\mpide-0023-windows-20111221\mpide-0023-windows-20111221\hardware\pic32\compiler\pic32-tools\bin\../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/include/avr/io.h:4:2: error: #error ******** This sketch or library uses AVR-specific code that may not work with the chipKIT platform. See this forum for more information on porting code to chipKIT [www.chipkit.org/forum/viewforum.php?f=7] ********
In file included from /gcode.h:19:0,
from /Reptier.h:28,
from Commands.cpp:23:
c:\documents and settings\quentin\desktop\mpide-0023-windows-20111221\mpide-0023-windows-20111221\hardware\pic32\compiler\pic32-tools\bin\../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/include/avr/pgmspace.h:4:2: error: #error ******** This sketch or library uses AVR-specific code that may not work with the chipKIT platform. See this forum for more information on porting code to chipKIT [www.chipkit.org/forum/viewforum.php?f=7] ********
In file included from /Reptier.h:29:0,
/fastio.h:2554:2: error: #error pins for this chip not defined in arduino.h! If you write an appropriate pin definition and have this firmware work on your chip, please submit a pull request
In file included from Commands.cpp:24:0:
/Eeprom.h:22:24: fatal error: avr/eeprom.h: No such file or directory
compilation terminated.
original message is found at : orignal message
I have a different setup (gen6) board so I could not help him perhaps someone else here is using repetier with the same hardware?!?!
Re: compile problems repetier-firmware and RAMPS1.4+CHIPKIT(clone) hardware
February 10, 2012 10:15AM
That's a Microchip PIC based board ... the Repetier firmware is written for Atmel chips, it won't work without proper porting, even though the Chipkit guys did a lot of work to allow their board to run Arduino code.
February 10, 2012 05:15PM
Is there a way I can modify the code to make it run on my board? Because I had this board laying around and I'm not really looking forward to shelling out $60 for a new arduino board if I can help it. But if there are no alternatives then I guess I'll have to suck it up
February 10, 2012 07:22PM
Quentin,
How about a swap. My Mega 2560 for your chipkit. I have a RAMPS + Mega that I did not use because I designed a new board. I always wanted to check out the chip kit.
Let me know
Roy
February 19, 2012 05:24PM
Hello Roy,
My dad wants to keep the max32 to use for other projects, but thank you for the great offer. I finally broke down today and bought an Arduino at RadioShack. I have compiled everything and it seems to work properly. I am learning how to connect everything at the moment, and things seem to be running smoothly so far.
Thanks for the help!
Quentin
