Repetier, Gen7 1.5 and the heating bed May 17, 2013 08:56AM |
Re: Repetier, Gen7 1.5 and the heating bed May 17, 2013 12:49PM |
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 12:21PM |
[...] /**************************************************************************************** * Sanguino/RepRap Motherboard with direct-drive extruders * * ATMega644P * * +---\/---+ * (D 0) PB0 1| |40 PA0 (AI 0 / D31) * (D 1) PB1 2| |39 PA1 (AI 1 / D30) * INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29) * PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28) * PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27) * MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26) * MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25) * SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) * RST 9| |32 AREF * VCC 10| |31 GND * GND 11| |30 AVCC * XTAL2 12| |29 PC7 (D 23) * XTAL1 13| |28 PC6 (D 22) * RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI * TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO * INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS * INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK * PWM (D 12) PD4 18| |23 PC1 (D 17) SDA * PWM (D 13) PD5 19| |22 PC0 (D 16) SCL * PWM (D 14) PD6 20| |21 PD7 (D 15) PWM * +--------+ * ****************************************************************************************/ [...] /**************************************************************************************** * Gen7 1.4.1 pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 71 #define KNOWN_BOARD 1 #if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega644__) && !defined(__AVR_ATmega1284P__) #error Oops! Make sure you have 'Gen7' selected from the 'Tools -> Boards' menu. #endif //x axis pins #define X_STEP_PIN 29 #define X_DIR_PIN 28 #define X_ENABLE_PIN 25 #define X_MIN_PIN 0 #define X_MAX_PIN -1 //y axis pins #define Y_STEP_PIN 27 #define Y_DIR_PIN 26 #define Y_ENABLE_PIN 25 #define Y_MIN_PIN 1 #define Y_MAX_PIN -1 //z axis pins #define Z_STEP_PIN 23 #define Z_DIR_PIN 22 #define Z_ENABLE_PIN 25 #define Z_MIN_PIN 2 #define Z_MAX_PIN -1 //extruder pins #define E0_STEP_PIN 19 #define E0_DIR_PIN 18 #define E0_ENABLE_PIN 25 #define TEMP_0_PIN 0 #define TEMP_1_PIN 1 #define HEATER_0_PIN 4 #define HEATER_1_PIN 3 #define SDPOWER -1 #define SDSS -1 #define LED_PIN -1 #define FAN_PIN -1 #define PS_ON_PIN 15 //our pin for debugging. #define DEBUG_PIN 0 //our RS485 pins #define TX_ENABLE_PIN 12 #define RX_ENABLE_PIN 13 #define SDPOWER -1 #define SDSS -1 #define SDSSORIG 4 // Needs to set this to output to enable SPI even if other SS is used! #define SCK_PIN 7 #define MISO_PIN 6 #define MOSI_PIN 5 #define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN, #define E1_PINS #endif [...]
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 12:28PM |
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 01:22PM |
out.println_P(PSTR("A"));out.println(analogRead(1)); for(i=0;ienablePin > -1) { pinMode(act->enablePin,OUTPUT); if(!act->enableOn) digitalWrite(act->enablePin,HIGH); } out.println_P(PSTR("B"));out.println(analogRead(1)); act->tempControl.lastTemperatureUpdate = millis(); out.println_P(PSTR("C"));out.println(analogRead(1)); #ifdef SUPPORT_MAX6675 if(act->sensorType==101) { WRITE(SCK_PIN,0); SET_OUTPUT(SCK_PIN); WRITE(MOSI_PIN,1); SET_OUTPUT(MOSI_PIN); WRITE(MISO_PIN,1); SET_INPUT(MISO_PIN); digitalWrite(act->tempControl.sensorPin,1); pinMode(act->tempControl.sensorPin,OUTPUT); } #endif } out.println_P(PSTR("D"));out.println(analogRead(1)); #if HEATED_BED_HEATER_PIN>-1 out.println_P(PSTR("E"));out.println(analogRead(1)); SET_OUTPUT(HEATED_BED_HEATER_PIN); out.println_P(PSTR("F"));out.println(analogRead(1)); initHeatedBed(); #endif out.println_P(PSTR("G"));out.println(analogRead(1)); extruder_select(0); #if ANALOG_INPUTS>0 ADMUX = ANALOG_REF; // refernce voltage for(i=0;ienablePin > -1) { pinMode(act->enablePin,OUTPUT); if(!act->enableOn) digitalWrite(act->enablePin,HIGH); } act->tempControl.lastTemperatureUpdate = millis(); delay(50); out.println_P(PSTR("B"));out.println(analogRead(1));
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 02:27PM |
Re: Repetier, Gen7 1.5 and the heating bed May 21, 2013 05:32AM |
if(act->enablePin > -1) { pinMode(act->enablePin,OUTPUT); if(!act->enableOn) digitalWrite(act->enablePin,HIGH);in the for-loop. What is that for? I don’t see any pin constants... What stands "enablePin" for?
Re: Repetier, Gen7 1.5 and the heating bed May 21, 2013 11:59AM |
