Repetier - Temperature Curve
Posted by smartroad
April 01, 2013 06:12AM
Just a quick question - the lower graph of the Temperature Curve, what does it represent? I know its a bit of a dumb question but I haven't been able to find it otherwise!
Cheers smiling smiley
Re: Repetier - Temperature Curve
April 01, 2013 07:34AM
Power going to the heaters I believe.
Brian
April 02, 2013 12:21PM
It is the pwm output of the currently active extruder in percent.
The temperature curve stop monitor after 60 minutes. How to continue to monitor the temperature on the heat bed and extruder?
Thanks
August 11, 2013 02:17AM
The default temperature curve shows the past 60 minutes and fills in new temps from the right. For autoscroll move to the right if you moved it before.
In the temperature menu you can select what period you want to see. Beside past 60 minutes you have all the hours printed before to select. These will not update after the hour has passed.
