Hi I am trying to integrate kisslicer using the Slicer Manager function. I added a new Kiss slicer and the path to it.
when I load a file in Repetier then Slice with the new Kiss slicer option, it open Kisslicer but then KS reports cant open file "--load" then cant open "ini". If you look at the messages in Repetier it says
"Slic3r Command C:Kisslicer.exe --load ...Slic3r.ini ...print-center C: box.STL
So it looks like it is trying to send Slic3r command line format for Kisslicer. Am I missing a step or is that a problem in Repetierhost?
Thanks
