i'm trying to get the Autobedleveling on a CoreXY-Setup to work but it doesn't quite work as expected.
Hardware:
Radds V1
X Max, Y Max Endstops
Inductive Probe at Z Min
Homing via 'G28 X0 Y0' and Probing the three defined points with 'G32 S0' works as expected,
except that after the probing the hotend is about 5mm above the bed and can't be lowered anymore.
The display shows a Z height of about 0.14mm which I assume is the difference between the probepoints.
See this picture for reference (just after G32 S0)
I thought that 'Z_PROBE_HEIGHT 3' defines that the hotend can be lowered 3mm after probing but that does not seem to be the case.
Greetings
