Thx again repetier you opened my eyes a little!
I have not considered the case of a failure, and you are totaly right that my schematic would pull up the heater mosfet and enable the heater!!
Tough i have a relay controlled by inverted ps_on pin (positive triggered) by which in this case would open up and disable the 12V supply its a bad practise i guess, and i should change that right?
Ive designed the heatbed driver in mind to be triggered by even a open collector input (for example the heater mosfet D8 which would pull down the driver) as well as a digital pin, so the input is generally pulled up.
Damn now i have to open up again and have a nice soldering session,... THX haha
Greetings, Alex
