Simply rename printer settings and press apply. Then you have 2 settings. But you can still only run one printer at a time, just select which one. You can start repetier 2 times and control 2 printers. You should be aware that this buts much load and resource usage on your computer. A better solution would be installing Repetier-Server. It uses nearly no resources and can handle even more printer at the same time. Next host release will also be able to talk directly to the server. So you can think of it as a printer spooler that works in the background (also accissible via internet).
Visit us on
Facebook and
Twitter!
