Repetier-Host Slic3r visualization problem
Posted by robotmar
August 30, 2012 08:16AM
Hi
If I configure Slic3r for Mach3/EMC in the folder Printer Settings, I do not see the wire path but only the Gcode.
With all the other G-code Flavor selections works perfectly.
It seems that the viewer does not recognize the A axis but only the E axis.
Andrea
Re: Repetier-Host Slic3r visualization problem
August 30, 2012 12:45PM
Yes, thats right. I have no EMC/Mach3 so I don't now what the difference is. If you say I need only to adjust A for E I can simply add it, because A isn't used anyway. So it would make no difference. What I mean is that internally each A will be mapped to an E.
August 31, 2012 05:31AM
Hi
If you can not otherwise, I should be fine too.
Is it important that only internally each A will be mapped to an E....
Andrea
September 04, 2012 01:36PM
Hi
I see that you have not implement in the new release (0.71) what I have ask you.
On which version do you think you can do it?
Andrea
September 04, 2012 01:42PM
0.71 was already planned and with the new slic3r version I wanted to make an early release. I Think the next version should contain it, if I don't forget it :-) So if not included remind me.
September 09, 2012 02:58AM
The update for Mach3/EMC is now in the sources on github. Will be included in release 0.73.
September 10, 2012 11:37AM
Hi Repetier
Very well, thank you...
Andrea
