I am starting to get used to the new version. I just upgraded to Linux Fedora-v17-x86_64, repetierHost 0.72, skeinforge 0.50 and have some issues. I did not find these as known issues in the forum. The terminal errors in item 4) may be user error? but help would be appreciated.
1)The display window blanks (loses the build platform and objects) when changing window size. Frequently it can be revived by maximizing or unmaximizing.
2) the repetierHost is expecting gcode file not to have an extension in stead of "filename.gcode" so it gives an error that it cannot find the file. The file can be manually selected, but that is less than convenient.
3) The program crashes spontaneousely at random times more frequently than it used to.
4) Most importantly a host of errors come up in the terminal (shown below). any clue to the cause of these errors?
[root@R5 Rich]# repetierHost
[root@R5 Rich]# Slic3r home:/root/.Slic3r
nvfx_screen_get_param:95 - Warning: unknown PIPE_CAP 30
nvfx_screen_get_param:95 - Warning: unknown PIPE_CAP 55
nvfx_screen_get_param:95 - Warning: unknown PIPE_CAP 56
nvfx_screen_get_param:95 - Warning: unknown PIPE_CAP 59
nvfx_screen_get_param:95 - Warning: unknown PIPE_CAP 58
X11 Error encountered:
Error: BadAlloc (insufficient resources for operation)
Request: 53 (0)
Resource ID: 0x22008B6
Serial: 84740
Hwnd: Hwnd, Mapped:True ClientWindow:0x22008B6, WholeWindow:0x22008B5, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x22008B4, WholeWindow:0x22008B3, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x22006B3, WholeWindow:0x22006B2, Zombie=False, Parent:[]]]
Control: System.Windows.Forms.ListView+ItemControl at System.Environment.get_StackTrace()
at System.Windows.Forms.XplatUIX11.HandleError(IntPtr display, XErrorEvent ByRef error_event)
at System.Drawing.GDIPlus.GdipCreateFromXDrawable_linux(IntPtr , IntPtr , IntPtr ByRef )
at System.Drawing.Graphics.FromXDrawable(IntPtr drawable, IntPtr display)
at System.Drawing.Graphics.FromHwnd(IntPtr hwnd)
at System.Windows.Forms.XplatUIX11.GetOffscreenGraphics(System.Object offscreen_drawable)
at System.Windows.Forms.XplatUI.GetOffscreenGraphics(System.Object offscreen_drawable)
at System.Windows.Forms.Control+DoubleBuffer.Start(System.Windows.Forms.PaintEventArgs pe)
at System.Windows.Forms.Control.WmPaint(Message ByRef m)
at System.Windows.Forms.Control.WndProc(Message ByRef m)
at System.Windows.Forms.ListView+ItemControl.WndProc(Message ByRef m)
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage(Message ByRef m)
at System.Windows.Forms.Control+ControlNativeWindow.WndProc(Message ByRef m)
at System.Windows.Forms.NativeWindow.WndProc(IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.XplatUIX11.DispatchMessage(MSG ByRef msg)
at System.Windows.Forms.XplatUI.DispatchMessage(MSG ByRef msg)
at System.Windows.Forms.Application.RunLoop(Boolean Modal, System.Windows.Forms.ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at System.Windows.Forms.CommonDialog.ShowDialog(IWin32Window owner)
at System.Windows.Forms.CommonDialog.ShowDialog()
at RepetierHost.view.Skeinforge.buttonSerachPy_Click(System.Object sender, System.EventArgs e)
at System.Windows.Forms.Control.OnClick(System.EventArgs e)
at System.Windows.Forms.Button.OnClick(System.EventArgs e)
at System.Windows.Forms.ButtonBase.OnMouseUp(System.Windows.Forms.MouseEventArgs mevent)
at System.Windows.Forms.Button.OnMouseUp(System.Windows.Forms.MouseEventArgs mevent)
at System.Windows.Forms.Control.WmLButtonUp(Message ByRef m)
at System.Windows.Forms.ButtonBase.WndProc(Message ByRef m)
at System.Windows.Forms.Button.WndProc(Message ByRef m)
at System.Windows.Forms.Application.Run(System.Windows.Forms.ApplicationContext context)
at System.Windows.Forms.Application.Run(System.Windows.Forms.Form mainForm)
at RepetierHost.Program.Main()
Error: BadDrawable (invalid Pixmap or Window parameter)
Request: 14 (0)
Resource ID: 0x22041D3
Serial: 84741
Hwnd:
Control: at System.Environment.get_StackTrace()
System.Exception: Generic Error [GDI+ status: GenericError]
at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in :0
at System.Drawing.Graphics.FillRectangle (System.Drawing.Brush brush, Int32 x, Int32 y, Int32 width, Int32 height) [0x00000] in :0
at System.Drawing.Graphics.FillRectangle (System.Drawing.Brush brush, Rectangle rect) [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:FillRectangle (System.Drawing.Brush,System.Drawing.Rectangle)
at System.Windows.Forms.Control.PaintControlBackground (System.Windows.Forms.PaintEventArgs pevent) [0x00000] in :0
at System.Windows.Forms.Control.OnPaintBackground (System.Windows.Forms.PaintEventArgs pevent) [0x00000] in :0
at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.ListView+ItemControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in :0
[root@R5 Rich]# Could not set X locale modifiers
