Idaholion Wrote:
> I am running RAMPS 1.4 on Arduino mega 2560 on a
> Prusa, looking at trying out Repetier. So, the
> first thing I figure I need to do is set up a
> configuration.h file, translating the numbers from
> my Sprinter configuration file.
They are the same plus some more. Names may have changed.
> Now, some things are obvious. (RAMPS 1.4 is still
> 33, 1 is still a 100K thermistor).. I don't know
> what #include
> #include "pins.h" do, I hope I can leave them
> alone.
It includes the board pinouts and activates the one selected, 33 = RAMPS 1.4 in your case. Thermistor type 1 is the same as in sprinter.
> Then the whole eeprom thing. Confusing, but I am
> still reading.
Here is a good doc if you haven't found it so far: [
www.repetier.com]
> Instead of 1 line with x,y,z,extruder calibration
> figures, there is a line for each of xyz with
> more eeprom stuff and I assume the calibration
> factor buried in the extruder info. The default
> values look different enough, looks like I may
> have to redo calibration for the machine.
> (sprinter says Axis steps per unit, Repetier says
> mm, is a unit a mm?) Since I didn't do the
> calibration originally (shared machine) this could
> be interesting
Sprinter units are mm. So steps/acceleration are the same. Extruder stuff is seperated to allow multiple extruders.
> Endstops. I go from a dozen lines and 3 things to
> either comment out to set to true or false to a
> bunch more, none of which appear to be commented
> to start out. (unless you can comment many lines
> at once.)
The same as in sprinter, but it was split for each end stop, so you can use different types of end stops in one printer.
> After all this whining, my question: Is there
> anyone out there who translated a sprinter
> configuration file to a repetier configuration
> file who would be willing to give a little hand
> holding to someone who understands the basics, but
> gets bogged down in firmware?
There is not really much to do. Get the steps per mm, thermistor, end stops and board id right and you are done for a first test and these are the same as in sprinter. The rest can be changed from Repetier-Host in the eeprom settings window if they don't match. If you have a special problem after that and can not track it down to a specific setting causing it, ask again.
Visit us on
Facebook and
Twitter!
