Hello Repetier,
I've a gen7 1.3 since a long time ago, working extremely well on your really nice firmware and host since quite a long time (I think I'm on of the first french to use your firmware on gen7 successfully).
So as each time, I thank you for your amazing job... It's really cool and operational!
Anyway, I acquired a new gen7 1.4.1 for a friend, and I'm trying your 71 motherboard configuration for the gen 7 1.4.1 where the analog pins changed a bit.
However, the heater 0 (on the analgo pin 0) doesn't not seems to work, I've got on the host a 500° temperature, against a normal temp on the bed.
I'm quite sure it's a firmware config problem, the temperature is visible with other firmware such teacup (I prefer your firmware actually... :p ),
I tried also changing configurations Arduino 0023 and 1 ...
So my question is, did you try the config on a real 1.4.1 or you just adjust the IO? If you didn't, would you have an idea about the problem?
perhaps the analog 0 (or PINA0) had been used or not set in input mode (tris) or I don't know why?
Many thanks,
Greets,
Edited 1 time(s). Last edit at 10/27/2012 11:45AM by Ghunt.
