Hi. i'm trying to get better extruder calibration, but the changes i do on firmware (customizing EXT0_STEPS_PER_MM value on configuration.h) do nothing.
Just now, when i open host software and execute "extrude 10mm of PLA at 200 temp" i think i get a bit more plastic extruded.
I was following
richrap.blogspot.ca]
so i used to mark 30mm with a pencil on PLA filament, and extrude 2 times 10mm each (or 4*5mm, i have change this with same results) and i expected take the exact amount on filament really extruded, and calibrate the extruder progressively.
But when i change the EXT0_STEPS_PER_MM (i did it the same with EXT1_STEPS_PER_MM) to the 373 initial value to (for example) 266, and 183....when i repeat the proof on hosting software i get exactly the same distance of filament been extruded when i exec "2 times 10 mm each"...
Any clue?
Thanks.
