X axis travel issue. December 06, 2012 03:23PM |
Re: X axis travel issue. December 06, 2012 04:15PM |
Re: X axis travel issue. December 06, 2012 08:34PM |
PATH_PLANNER_CHECK_SEGMENTS (default 10)
Sets how many line segments can the path planner use for path optimization. The maximum possible value is MOVE_CACHE_SIZE-2. Higher values need more computation time, which can cause blocking for many short subsequent moves. If this happens you will see BLK messages in your log and then you now the value is to high for your printer settings. If you set the value too low, you will get unneeded acceleration/deceleration sequences.
Re: X axis travel issue. December 07, 2012 11:30AM |
Re: X axis travel issue. December 07, 2012 11:42AM |
// You can disable endstop checking for print moves. This is needed, if you get sometimes // false signals from your endstops. If your endstops don't give false signals, you // can set it on for safety. #define ALWAYS_CHECK_ENDSTOPS false
