Hi there!
Just got my new printer and was tinkering around with the software/hardware and encountered a few problems that stumped me and would like to seek some advice from everyone here.
I am using a durbie prusa mendel with a Gen6.d board on a Macbook OS X version 10.6.8.
1. Unresponsive connection
When I try to connect the printer, it will start to connect and I will end up with "1 commands waiting" and the printer would not respond to any commands from me. Instead I would see the commands i sent being queued up behind the 1 mysterious command. I have to push this small button on the board to sort of like get myself out of this "1 commands waiting" problem and some time, I got disconnected after pushing the button. This is my connection setup:
PM 11:55:16: Attempting to connect to printer
PM 11:55:16: Connection opened
< PM 11:55:21: start
< PM 11:55:21: echo:Free Memory:799 PlannerBufferBytes:1168
< PM 11:55:21: echo:Using Default settings:
< PM 11:55:21: echo
teps per unit:
< PM 11:55:21: echo: M92 X40.00 Y40.00 Z2078.72 E514.00
< PM 11:55:21: echo:Maximum feedrates (mm/s):
< PM 11:55:21: echo: M203 X250.00 Y250.00 Z3.00 E25.00
< PM 11:55:21: echo:Maximum Acceleration (mm/s2):
< PM 11:55:21: echo: M201 X4500 Y4500 Z40 E5000
< PM 11:55:21: echo:Acceleration: S=acceleration, T=retract acceleration
< PM 11:55:21: echo: M204 S1500.00 T1500.00
< PM 11:55:21: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s)
< PM 11:55:21: echo: M205 S0.00 T0.00 B20000 X10.00 Z0.20
< PM 11:55:21: echo
ID settings:
< PM 11:55:21: echo: M301 P22.20 I1.25 D99.00
< PM 11:55:24: echo
D init fail
< PM 11:55:24: workDir open failed
< PM 11:55:24: FIRMWARE_NAME:Marlin; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[
www.mendel-parts.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1ok
2. Printing stop halfway
On rare time, I managed to get it thru and able to get the printer to respond to me, When I load the file in to run, it will print smoothly till it reach a point where the printer will just stop printing and the software become unresponsive. I also realised the temperature graph stop updating when the print stop halfway. Its very weird because I tried with other design and it will stop at one point during the print and the stopping layer seems to be random. Sometime, it could be 220+ layer out of 260, sometime it could be 25 out of 60.
I'm sorry if I left out any system info. let me know if I do so I can provide the necessary information.
Thanks!
Edited 1 time(s). Last edit at 12/16/2012 11:26AM by wilsonli_86.
open |
download -
(194.1 KB)
