I have a problem. The temperature sensor appears to be affected by negative movement on any axis. As a result the temperature just spikes significantly. This causes the bed to stop heating and causes warping.
I have a Mendel Max 1.5 using a RAMPS 1.4. On other firmwares I don't seem to have this problem but with the Repetier firmware this happens. Attached is a screenshot of the Temperature Curve.
open |
download -
(139.5 KB)
