Hi i use last version of this software and these are my suggestions.
1) When i stop the work in pause, and i disconnect from printer, can you add an option for save work where it's pause. Or can you add an option to restart work of last point when you reconnect.
2) When you move manually i have a problem, the printer exit from max range of movement XYZ, this problem verify when commands accumulate.
Thanks for the software.
